walkerx
Feb 24, 2019Guide
Orbi and Sky
I heard that netgear had enabled the ability for some of their devices to work with Sky and its MER configuration, does anyone know if this will happen with the Netgear Orbi or are we assigned to usi...
Feb 24, 2019Guru - Experienced User
I was curious, for some DMZ can be used if Orbi users want to use the Orbi base as a router and use its routing functions. What DMZ IS for when having two routers on the same network. However of course, Orbi in AP mode works too if more advanced users want to use other routers or firewalls in there configurations.
Good Luck.
