Drewbey
Jun 28, 2017Aspirant
Orbi and switch setup.
Hello, I just have a quick question. I just set up my new network config today at home. I have fiber internet installed, so I basically just have a cat 5 cable coming into the house. I plug that into...
- Jun 29, 2017
I have almost this same setup. Did you ever get it up and running. If not try to unplug the switch from power and ethernet from Orbi. If you just switched routers and never power cycled the switch all your hard wired devices think they are still on the old network. Replug in the power and ethernet from Orbi. And you should be go to go.
Nsiddons
Jun 29, 2017Apprentice
