angularone
Jul 30, 2017Aspirant
orbi and U-verse how to keep firmware updated
ok guys I used RonV42 instructions to hook up orbi a guest SSID. all is working well. my question is on the lines of how do keep the firmware updated on the orbi?
DarrenM
Aug 01, 2017Sr. NETGEAR Moderator
Hello angularone
The firmware is updated automatically.
DarrenM
- angularoneAug 01, 2017AspirantI understand that in orbi mode. But since I set it up under the att U-verse as an Ssdi guest it does not show under orbi app. So how does one keep firmware updated?
- st_shawAug 01, 2017Master
As said already, the Orbi updates firmware automatically, with no user input required. This, of course, requires Orbi to be on a network with Internet access. I have no idea what an "Ssdi guest" is, but If you have Orbi on a closed network with no Internet access, which is unlikely, then you will need to manually update the firmware by downloading the ffirmware from Netgear onto a PC, logging into Orbi with a web browser, and uploading the file from your PC.
