angularone
Jul 30, 2017Aspirant
orbi and U-verse how to keep firmware updated
ok guys I used RonV42 instructions to hook up orbi a guest SSID. all is working well. my question is on the lines of how do keep the firmware updated on the orbi?
angularone
Aug 01, 2017Aspirant
I understand that in orbi mode. But since I set it up under the att U-verse as an Ssdi guest it does not show under orbi app. So how does one keep firmware updated?
st_shaw
Aug 01, 2017Master
As said already, the Orbi updates firmware automatically, with no user input required. This, of course, requires Orbi to be on a network with Internet access. I have no idea what an "Ssdi guest" is, but If you have Orbi on a closed network with no Internet access, which is unlikely, then you will need to manually update the firmware by downloading the ffirmware from Netgear onto a PC, logging into Orbi with a web browser, and uploading the file from your PC.
