j1n's avatar
j1n
Apprentice
Mar 15, 2018
Orbi and WEP
I’ve been under the assumption that using WPS encryption is insecure, and the best encryption is to use WPA2 (hopefully with the Krack exploit patched). I noticed that it seems the Orbi system does use WPS through pushing the sync button on the router and/or satellite(s). Previous routers I’ve owned had the ability to completely turn off WEP.
With that in mind, could someone comment on how secure using WEP (through the sync button) is when using an Orbi System?
Also, does anyone think it may be beneficial if down the road Netgear added the ability for an end user to choose if they want WEP enabled or disabled on each individual device through a future firmware update (of course, after Netgear fixes the bugs that have been causing a lot of people to experience seemingly random wireless internet disconnections)?
  • You are mixing up a few things here.
    WPS is not the same as WEP. They aren't even the same type of thing.  WPS is a method for two devices to associate with each other without using a password or the WiFi SSID.  WEP and WPA2 are encryption methods. WEP is insecure.  WPA2 is the most secure.
    WPS will only work on devices that support WPA or WPA2 encryptiion.
    Orbi doesn't even support WEP.
    WPS can be less secure than using a passphrase.  Orbi only supprts the push-button mode of WPS, which is the most secure WPS method.  However, this also means anyone that can touch your Orbi can access your network via WPS.
    • j1n's avatar
      j1n
      Apprentice
      You are right. I did mix up “WPA” & “WEP” with WPS. Regardless, WPS can be turned on or off on the Orbi outdoor wireless satellite (RBS50Y) for security purposes. I guess that doesn’t make sense with the Orbi Router and indoor satellite(s).
      • st_shaw's avatar
        st_shaw
        Master
        I'm not sure if you have a question anymore, but clearly, WPS should be turned off on an outdoor device.
