marknt's avatar
marknt
Tutor
Jul 31, 2018
orbi and wifi extenders
Hi, ive been reading up...
My virgin hub 3.0 doesn't quite cut it 3 floors up.
I've got ex6120's and ex6130's - thinking i could daisy chain them.. I cant!
So... I'm now tied between a new r8000 router and an ex8000 extender (both tri-band), or Orbi rbk50/53.
My question is... If i go for the Orbi (works out slightly cheaper, and reviews are slightly better) - especially the rbk50 (rbk53 isn't quite so competitive), can i then extend (with the ex6130) from the satellite, or would the extender still 'connect' back to the router?
Thanks in advance...
  • FURRYe38's avatar
    Orbi satellites will only connect to is main base router. The EX unit will not be needed if you decide to go with the Orbi system.
    Whats the size of your home? SqFt?
    • marknt's avatar
      marknt
      Tutor
      Thanks for the answer.
      I know the satellite will only connect to the router.
      My question is, with a 'single ssid network' would an additional extender extend from the satellite (as it would be physically closer to the satellite), or sync all the way back to the router?
      Not sure what the house is in square footage - 4 bed, 3 storey modern semi/town house. Living room and kitchen on ground floor. 2 double bedrooms on first, and 2 double on second.
      Virgin comes in behind the tele, in the corner of living room, but I'm going to cat5 from that to the bottom of the stairs, where i would put the new router, putting virgin in modem only.
      Then satellite probably on top floor - due to suitable places to plug it in... But if the router isn't powerful enough to get to the top floor to 'feed' the satellite, it might have ti go on the first floor... Which raises my question about extending the satellite with an extender...
      • FURRYe38's avatar
        The extender would connect to either satellite or router.
        I have a 5000sq ft home, Use the base router at one end of the house and 1 satellite at the other end. 40 feet in between. I have great coverage and performance. I would highly recommend trying the Orbi out with Just one satellite. Placement will be key of course. No closer than 30 feet in between the router and satellite and between satellites if you get two satellites.
