walkerx
Feb 24, 2019Guide
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.
I...
- Mar 07, 2019
resolved the issue
picked up google wifi - setup in about 20 minutes - all devices working and so is their app
wifi might not be ac3000 but at least everything works
Chuck_M
Feb 24, 2019Mentor
To properly diagnose this, you will need to provide some additional details:
What make/model of modem are you connecting to?
What mode is Orbi operating in? (AP or Router)
What is your firmware version on both your router and satellites
What is the status of beamforming, fastroaming and daisychain check boxes
Are either of your satellites hardwired backhaul?
walkerx
Feb 24, 2019Guide
My orbi's are connected to a switch, which is connected to Opnsense router
Orbi is in AP mode
v2.2.1.210
All enabled
Both are hardwired backhaul but have found issue with one, where it states that the backhaul is 5Ghz even after reseting the unit, was previously working via ethernet backhaul
