walkerx's avatar
walkerx
Guide
Feb 24, 2019
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.   I...
  • walkerx's avatar
    walkerx
    Mar 07, 2019
    resolved the issue
    picked up google wifi - setup in about 20 minutes - all devices working and so is their app
    wifi might not be ac3000 but at least everything works
