walkerx
Feb 24, 2019Guide
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.
I...
- Mar 07, 2019
resolved the issue
picked up google wifi - setup in about 20 minutes - all devices working and so is their app
wifi might not be ac3000 but at least everything works
Feb 24, 2019Guru - Experienced User
Might contact one of the forum Moderators to see if they can pass this along. Blanca_O ]
It's working on my Tab S2. I satellite appears along with connected devices. Can select the satellite and see whats connected to it.
- walkerxFeb 24, 2019Guide
well mine don't work and shows both satellites as offline and for one its showing incorrect ip address, probably would have been easier for me to stay with tp-links and have them setup all over the house as never had issues with them when i used them.
hopefully should get replacement system by tuesday, just hope that works, i should have sent this back last time was having issues with the product losing it settings
- FURRYe38Feb 24, 2019Guru - Experienced User
Ya, and having it not show as working in the app, probably is a indication that the satellite is bad as you said in your other thread.
- walkerxMar 05, 2019Guide
well installed my replacement orbi's
picked up in app, but not one of the units (main or satellites) show what devices are connected and to which satellite, but if i go into device list on the app, it shows devices connected.
if i go to web interface on tablet it shows devices connected and which orbi connected to
