walkerx
Feb 24, 2019Guide
Orbi Android App
I've noticed with the Orbi Android app, running on Pixel 3 XL if I'm connected it to a orbi satellite it will not work and just says can't connect to network, even though I'm connected to it.
I...
- Mar 07, 2019
resolved the issue
picked up google wifi - setup in about 20 minutes - all devices working and so is their app
wifi might not be ac3000 but at least everything works
walkerx
Mar 05, 2019Guide
CrimpOn
That is what is supposed to happen but wasn't on mine, its finally showed devices on satellite after a few days.
Well its working to a degree, the wired satellite is now showing as not connected in the app, but is on rbr50 gui interface.
Still can't access the app when connected to a satellite, bit daft you have to be connected to the main orbi to see anything.
walkerx
Mar 06, 2019Guide
Even after further reboots, the wired satellite still shows as not connected/online in the app, yet through browser it is fine.
- walkerxMar 07, 2019Guide
resolved the issue
