Jamesom
Dec 23, 2018Guide
Orbi AP Confusion
Hey guys,
Networking amateur here, hoping someone can help clear some things up for me. I recently purchased an Orbi RBK50 for a new house after recommendations from a friend. I was experienci...
Jamesom
Dec 23, 2018Guide
Hmm interesting, thanks for the reply, so if I disabled the WiFi on the Nighthawk then I am letting the router do it's thing for the direct wired connections and the Orbi's are exclusively handling all Wifi connections.
My initial thought of having the Nighthawk WiFi and Orbi WiFi working in harmony isn't possible then? The Nighthawk can't function as another element of WiFi coverage that is part of the larger mesh network along with the Orbi? It's one or the other?
randomousity
Dec 23, 2018Luminary
Sort of. You can also plug devices into the Orbi router and satellite, but their IP addresses will still be assigned by the Nighthawk, and the Nighthawk will still be the one making the routing decisions. All the wifi will be handled by the Orbi, but both the Nighthawk and Orbi can handle wired connections. Generally, you only want one router on your network (putting the Orbi in AP mode means it won't count as a router for these puposes). You'l get one IP address from your ISP, and then your Nighthawk will give all your devices something in, say, the 192.168.1.x address space, using network address translation (NAT) when it communicates with the internet. But if the Orbi is in router mode, it will will also get an IP address from the Nighthawk, and will have to use a different IP address space, say, 192.168.2.x for devices connected to it. You won't be able to use 192.168.1.x on both the Nighthawk and Orbi. And the Orbi will also have to do NAT to commuicate with what it thinks is the internet, but which is actually only your Nighthawk's network. Double-NAT can cause problems, and is something you should avoid.
And no, the Nighthawk can't function as part of the mesh. Right now, generally, you can only use routers and satellites sold as part of a mesh system (Orbi, Velop, Google Wifi, etc.) in a mesh system. None of them are compatible with each other, and you can't even just add another Netgear router to the Orbi to expand it, can't add another Linksys router to a Velop system, etc. Maybe someday there will be more compatibility, but not yet.
If you use the Orbi and Nighthawk with the Orbi in AP mode, and both with the same SSID and password, you will basically have two different networks with the same name and on the same IP network. But, at a functional level, it won't really be any better than giving them different SSIDs and passwords, other than saving you from having to configure your devices twice. You'll also probably have some problems with some functions. If you use file sharing, devices connected to the Orbi and Nighthawk will be on different networks (despite the SSIDs being the same), and won't be able to see each other. If you use access control lists, any devices that move around will have to be added to both. Same with any reserved IP addresses. And, any changes you make will also require logging into the Orbi to change there, and then logging into the Nighthawk to make the same changes again there. If you use the Nighthawk as the router, and the Orbi as the APs, then you'll basically only have to log onto the Orbi to change wireless settings (SSID, password, which channels you use), and all other things will be done from the Nighthawk (ACLs, reserved IPs, blocked sites and services, scheduling, etc.).
- ekhalilDec 23, 2018Master
randomousity wrote:
.......... Maybe someday there will be more compatibility, but not yet.
Beside what randomousity mentioned, you can theoritically have Orbi and your R7800 router use the same SSID but with different channels (to avoid radio interference). The only thing that is not guaranteed to work is roaming. Orbi supports 802.11k, v and r. Only if the R7800 router and your devices support these standards you will be able to roam without issues between the coverage areas of the 2 base stations. I could not find information about R7800 roaming specs.
Most probably you will not see issues with idle roaming (when the devie roams between base stations in idle mode), but you might see drops if you roam while using apps like Skype.
- JamesomDec 23, 2018Guide
I really appreciate the thorough responses, thanks guys. I disabled the WiFi radios on my Nighthawk and I think I've got it all squared away now. Thanks for helping me make sense of all this.
- nicksowerbyDec 29, 2018Aspirant
As a matter of interest only. I am using a 2.4wireless on my modem to connect to a specific connection that requires more effort to connect to if orbi disconnects as my modem a telstra gateway is always rock solid. I use channel 1.
On my orbi i use 2.4 on channel 11.
I have never had any issues doing this, I am aware of the general concensus on this forum not to do this but it works for me.
Just my 2 cents worth
