PaulMoore's avatar
May 10, 2017
Orbi appears to be corrupted by auto update, won't boot
Hi,
So, I have an Orbi Router that's worked fine since purchase in 12/16, but had a problem in the early morning of 5/4/17, and now crashes on boot. I can see the DHCP processes start to vend IPs on the LAN ports, but it crashes before it can start the WiFi process, with a blue then red ring light sequence.
Yes, I've done the factory default, with no change.
Is there a procedure to recover from a corrupted firmware load ?
Also, I have the situation where the S/N for my unit was registered, and then the unit was returned. So far, support appears incapable of dealing with this. though I've emailed by purchase receipt.
What's the most effective way to solve these 2 problems ?
Thanks,
Paul Moore
    • PaulMoore's avatar
      PaulMoore
      Tutor
      Thanks for the process info, and I successfully used it to reload the latest and previous Orbi firmware via TFTP, but unfortunately it appears to not be a firmware issue, as the problem still occurs.
      The Orbi boots, with the slow blink white LED, then goes solid white, solid green, flashes red, then off. The cycle then starts again. Sigh.
