Jgoldsti's avatar
Nov 26, 2020
Orbi armor blocking wyze lock gateway setup
I tried to set my wyze lock gateway up using my orbi rbr50 with armor enabled. The setup kept failing at the stage of connecting to the wyze cloud.
I finally turned off armor and the lock gateway setup without a problem.
I checked the armor threats blocked and there is nothing related to connecting to the wyze cloud.
is there a way to tell armor to let certain connections occur or to see connections it is blocking?
every firewall I have used allows both of these capabilities.
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Jgoldsti wrote:
    Is there a way to tell armor to let certain connections occur or to see connections it is blocking?
    This question is more likely to get an informed response if posted in the communit forum for the Armor product:
    https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
    My observation is that few people who watch the "general Orbi topics" forum have activated Armor.  It's not that we don't want to help; we are just seriously ignorant about the product.
