zcobrausa
Nov 13, 2017Aspirant
ORBI Authenication error
I have had the RB50 router with 2 satellites for about a year and it has worked great. After the last Android update my phone loses connection and shows "authenication error occurred". I have checked the firmware on the ORBI and it was the latest edition. If I turn off the wifi on the phone and then turn it back on it works for a while and then I get kicked off again. It only happens at home and not on other wifi networks so I assume it has to do with the ORBI software. Any fixes?
- DarrenMSr. NETGEAR Moderator
Have you tried to forget the orbi network on the phone and connect to it again?
DarrenM
- zcobrausaAspirant
I have tried that. I also tried running the phone in safe mode. Sometimes the phone will stay on the network for a couple hours and other times just a few minutes. If I turn the wifi off and then back on it will reconnect.
what android phone are you using?
DarrenM
- SkalskyTutor
My wife & I have the same exactly problem with Samsung S6 after security update on my phone. Now it drops we off the router and is very flakey. We have the ORBI with 2.0.0.74 firmware
