machaf
Mar 29, 2019Follower
Orbi: Automatically adjust for daylight savings time ISSUES
When I have Automatically adjust for daylight savings time checked in the router it screws up traffic meter and the VPN connection.
Traffic meters reads 0
VPN connections constantly drop and...
randomousity
Mar 30, 2019Luminary
Just came across your post and decided to check my settings. I had automatically adjust for daylight saving time checked, and have noticed that the traffic meter is useless, showing next to no usage, and only for last month. So I unchecked to automatically adjust for DST, and then looked at the traffic meter again, and, lo and behold, the usage volumes for all time periods seem to be about what I'd expect them to be.
They do all say 0:0 for connection time, whether it's checked or not, but I don't know if that's just how it displays for a constant connection. But so odd to discover that a time setting is affecting the traffic meter display.
neerajv
Mar 31, 2019Tutor
Everytime after few hours, the settings automatically gets checked and then stats become zero unless i again uncheck it.
Looks like netgear is aware of the issue but has done nothing since last 1 year.
-Neeraj
