LyndB
Aug 01, 2021Aspirant
Orbi AX600 plus nighthawk ac2600 switch off wifi
Hi, I have a Nighthawk X4s Ac2600 modem/router, but lacked wifi in some parts of the house, so just installed Orbi AX6000 (2 satellites), I've changed Orbi to AP, but wifi still available from the AC2600. How do I switch off Wifi from this (Logging in to netgear login no longer shows Ac2600 info, only Orbi)?
Be gentle, I'm not the most technical so may be missing the obvious! :smileywink:
Many thanks
Lynda
> [...] I have a Nighthawk X4s Ac2600 modem/router, [...]
None of that is a model number. Look for "Model" on the product
label.Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for the LED descriptions. Pay particular attention to something
like a "WiFi On/Off button with LED". Further reading might not hurt,
either.In addition to the button, I'd expect there to be an option like
"Enable Wireless Router Radio" (for each radio) hidden somewhere among
the ADVANCED settings.> [...] (Logging in to netgear login no longer shows Ac2600 info, only
> Orbi) [...]> [...] wifi still available from the AC2600. [...]
Power off the Orbi, and connect a device to the "Ac2600" (whatever it
is)?- LyndBAspirant
Thanks, Model is D7800-100UKS.
Will try switching off Orbi.
I had (I thought) disabled wifi in the router settings for the D7800 online in the router wifi page, prior to switching on the orbi. There doesn't seem to be a button/switch of any kind on the router.
- LyndBAspirant
Apologies Antinode,
Found wifi on/off button, looks just like all the other LED lights on the front, and hadn't realised it was a button rather than just another LED! :smileyfrustrated:
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
LyndB wrote:Hi, I have a Nighthawk X4s Ac2600 modem/router, but lacked wifi in some parts of the house, so just installed Orbi AX6000 (2 satellites), I've changed Orbi to AP, but wifi still available from the AC2600. How do I switch off Wifi from this (Logging in to netgear login no longer shows Ac2600 info, only Orbi)?
Many thanks
Lynda
