Jezza73
Apr 24, 2020Aspirant
Orbi blocking some web traffic
I recently bought an Orbi system, and I have found that for some reason it is blocking certain web traffic. It will allow Stan to connect, but blocks Netflix. It won't allow my AppleTV to update it...
Apr 28, 2020Guru - Experienced User
Jezza73 wrote:I recently bought an Orbi system, and I have found that for some reason it is blocking certain web traffic.
It will allow Stan to connect, but blocks Netflix. It won't allow my AppleTV to update its software. It won't allow graphic content in emails and won't allow access to certain websites.
I have all access restrictions switched off, and my main wifi doesn't have any of these problems (but has crappy range).
Is there any way to change the Orbi settings to stop it blocking web traffic?
Retired_Member
Apr 28, 2020please allow the OP to read the following:
https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125
