NigelCheetham
May 19, 2018Aspirant
ORBI Blocks Access to Playstation Network
We recently installed the Orbi system with two satellites, to replace my existing Netgear Router (model R6400). Once setup, my son lost his ability to log into the Playstation network (he has a Plays...
djimrie
May 23, 2018Aspirant
Hi there, I just hit exactly the same issue - connected my new Orbi system up today and suddenly none of the 3 PS4's we have in the household could log in to PSN. They all have Internet access just fine - can browse pages, etc.
I stumbled across the solution (well, a workaround), which is to configure the Internet settings manually, leave getting the IP address and DNS as automatic, but change the MTU from 1500 to 1472. As soon as I did that, can now login to PSN just fine on all of the PS4's!
Very annoying - it worked fine with Google Wifi, and previous Netgear router, just not Orbi........hope that helps!
NigelCheetham
I lowered the MTU to 1472 - but it hasn't solved the problem. The Playstation Network is still unavailable.
Thanks though,
Nigel
