sangweb
Dec 03, 2020Aspirant
Orbi broadcast additional ssid calls netgear01
So I have RBR40 & RBS20. There is an additional ssid calls Netgear01, is this the backhaul network between the router & the satellite? I've tried to connect to it but unable to do so using the password provided. TIA.
sangweb wrote:So I have RBR40 & RBS20. There is an additional ssid calls Netgear01, is this the backhaul network between the router & the satellite? I've tried to connect to it but unable to do so using the password provided. TIA.
The 5G backhaul between satellite and router does not broadcast an SSID.
The SSID (that is not broadcast) can be found by opening this web page: http://orbilogin.net/hidden_info.htm
The credentials are the usual Orbi web credentials: "admin" and the password.
- sangwebAspirant
then why do I see this Netgear01 being broadcast as the strength is always the same as mine. Can't login the url you've provided but I can access the router on 192.168.1.1.
- sangwebAspirant
NVM, I logged in & don't see this SSID on the list. It's still a mystery where this ssid comes from.
