Frankpjr
Mar 13, 2017Aspirant
Orbi cannot connect Old Windows Mobile 6.1 device to WiFi, Only to Guest Network
I have now had this Orbi and 1 satellite installed for 1 week and I seem to have only 1 issue that I had not had with old router. I have a Palm TreoPro that cannot connect to WiFi router, it will onl...
Frankpjr
Mar 15, 2017Aspirant
Sorry should have been clear that I have the guest network setup with wep2-TKIP just with a much shorter passphase. And I meant that the old router was using exact same passphase and wep2 protection. Just odd how treopro does not even see the main network, only guest
st_shaw
Mar 16, 2017Master
OK. Thanks.
I have an older 802.11b device that will work with Orbi if I manually enter the SSID and passphrase, but the device does not appear in the Orbi list of attached devices, nor in my router's list of devices. The device works though.
Sometimes you just need to replace old gear.
