bha19's avatar
bha19
orbi cbk 40? and 2.4 smart appliance
I thinh I have the Orbi cbk 40 and just bought a smart kitchen appliance that only works on 2.4 band. the problem is when I try to log in on the kitchen device it say incorrect password/refuse to connect. is there a way for Orbi to recognize this appliance since it does not work on 5.0 band?
  • Guest network seems to have worked although it said bad network it booted up.
  • FURRYe38's avatar
    Try this. Turn OFF the RBS. Then the power output of the 5Ghz radio to 25%. Be sure that 20/40 MHz Coexistence enabled. Under Advanced Tab/Advanced Settings/Wireless Settings. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
  • CrimpOn's avatar
    CrimpOn
    Incorrect password sounds pretty definite.  "I see the WiFi system, but when I attempt to connect it rejects my password."
    I often fumble when keying passwords into tiny phone screens, and I HATE it when the app does not actually display what I have entered (shows dots instead) and I cannot verify it was entered correctly.
    Would you mind sharing what this kitchen appliance is?
    • bha19's avatar
      bha19
      it is called a Tokit. It is also not 5g compatible. i also have a smart oven and that connects with no problem.
      • CrimpOn's avatar
        CrimpOn
        Fascinating that I am totally unable to find any sort of installation or user manual on the web site.
        Good old Google found a User Manual here: https://www.manua.ls/tokit/omni-cook/manual
        Unlike so many Internet of Things (IoT) devices which use a smartphone app for setup, this Tokit gizmo has the user make a WiFi selection on the screen and physically enter the password.
        As the device has only a 2.4G WiFi chip, it can detect only 2.4G WiFi networks.  Thus if the Tokit shows the Orbi WiFi Service Set IDentifier (SSID), it must have detected the Orbi 2.4G network.  None of the typical smartphone app "requires 2.4G problems" would seem to apply.
        Also, the CBK40 system is WiFi5 (802.11ac), so the issue that affects some IoT devices when connected to WiFi6 systems is also not a factor.
        Is there anything unusual about the WiFi password?
        I would be tempted to enable Guest WiFi on the CBK40 and give it a very simple password, maybe something like "tokitsucks", and see if it will connect.
