skyhawk214's avatar
skyhawk214
Orbi CBK40 having lots of problems with satellites
My landlord installed an Orbi mesh system for the house I live in, and it's been nothing but confusing problems ever since. I'm helping to fix it, but I do not know the credentials to get to the login page for the router. I'm just doing research so that when they get home from work tonight, I can go ahead and make the changes necessary.
I've noticed that when my computer was connected to a plug-in satellite, I cannot sync internet time, and it's 11.3 seconds behind on my computer, and 1.5 seconds ahead on my phone (according to time.is) Every single time. When it's wireless in the same room as the router, no time issues at all, everything works the way it should. This all only happens when I'm getting my WiFi via a satellite.
I can't connect to any VPNs either. The connection fails.
WiFi calling from AT&T also doesn't work when connected to a satellite. The connection never initiates, and when it tries to do the handoff from cellular to WiFi, it fails and the call drops.
If I ping 8.8.8.8 (Google's DNS) I get a response time in the 300ms range.
My Nintendo Switch is only able to get NAT type F. When I'm wirelessly connected to the router, then I get NAT type either A or B. I am unable to play any games online at all.
It seems like all the problems stem from being connected to a satellite, rather than the router itself.
Ideas?
Note: I am using the Orbi cable modem with this setup, all Orbi equipment. I have Xfinity for internet but I am not using their gateway.
