tmbrw4545's avatar
tmbrw4545
Follower
Dec 09, 2020
Orbi CBR 40
I set up my new Orbi CBR 40 moden router from my xfinity supplied unit and I am having more issues and wifi outages than with the xfinity unit!! why?  I have one satellite as well.
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
