Saurabh1990
Mar 28, 2023Aspirant
Orbi CBR40 connecting to AT&T 210 router need help
Hello Everyone, I recently switched from Xfinity to AT&T fiber.: 300 Mbps. I had my CBR40 with Xfinity earlier which was connected thru the coaxial cable and worked fine. Now AT&T they have set...
Mar 28, 2023Guru - Experienced User
The CBR requires a cable ISP Coax line to connect to operate in it's intended design. as the Orbi gets it's internet access from the Coax line.
You can give this a try and use the CBR40 in a faux AP mode configuration:
