LawJolla
Jun 08, 2020Aspirant
ORBI CBR40 slow device speeds when not shown as connected device
Orbi CBR40, v2.3.5.12__1.0.8
Hello!
When a particular computer connects to the Orbi, it shows up as a connected device with proper speeds (320mbps). But soon after, the computer is lost as a connected device, speed degrades to 15mbps (and it is still connected / online).
Any help is great. Please see video and note the IP address of the computer doesn't show as a connected device.
The Orbi is line of sight and25 feet from the computer.
In the video, you can actually see it lose speed during the speedtest.
Please post about this over in the Orbi with built in cable modem forum:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
- LawJollaAspirant
Given that this question doesn't concern the cable portion of the modem, this forum is appropriate.
Do you have a RBS connected as well?Is the PC wired or wireless connected to the CBR?
What is the mfr and model# of the wired and wireless adapters in this PC?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
