wvwalt
Dec 13, 2017Tutor
ORBI Change satellite password
Orbi Satellite - can login to the satellites with "admin/password", even after I change the password for the Orbi router.
Question: How can I change the password for the Orbi Satellites?
Already changed password on router. Question concerns the Satellite devices. You can access the satellites by pointing a web browser to the IP of the Satellites. But. you can't change the password.
- BillYoungLuminary
wvwalt:
You are correct as far as I know. The satellite password must be the same as the router password. Why? The satellite connects to the router and gets all of its information from the router. So the satellite at this point cannot have its own password. Sorry about that.
- wvwaltTutor
Allow me to clarify. Router, at 192.168.1.1 has password of blahblah.
satellite is on network with an IP of 192.168.1.180. I can open a web browser, and enter 192.168.1.180 in the address bar and get a login prompt for the satellite. The login is NOT admin/blahblah. The login to the satellite is still the default of admin/password.
i would like to change the login of the satellite to be the same as the login to the router, which is admin/blahblah. I see no option to do this. Is it possible?
- DarrenMSr. NETGEAR Moderator
I will look into this and see if I can get a answer.
DarrenM
