diftimi
Nov 22, 2016Follower
Orbi configuration
Hello. I intend to replace my current wifi setup at home from a router + 3 APs (gigabit wired) to an Orbi system, the RBK53. I've seen that the recomended way to pair the satellites with the Orb...
Retired_Member
Jan 02, 2017I would not recommend this product due to its weak security features. While it gives strong WiFi signals but weak security has stopped me from using the product for serious business use. Take for example, when connected to Orbi, many applications prompt and warn me of the risk of unauthenticated security risk. Its MAC address access control is disabled when you set up Orbi as Access Point. And even if you set it up as a router and enabled its MAC address control, blocked devices can still connect to Orbi which is unusual.
So, instead of burning of my money and throw away this expensive toy, I turned off its Wifi and use it as a ethernet port for connection to my TV in a WiFi restricted corner of my house. No, unless Netgear resolves this security issue, I would not recommend buying this product which is very expensive and not worth the money.
Ely
Jan 02, 2017Luminary
Retired_Member your description of the issue makes me believe that this is related to user related misconfiguration and not a problem with the security of the Orbi, can you post proof of your claim and elaborate more on the supposed security risk?
- Retired_MemberJan 02, 2017
Are you a judge or what? Why should I proof this to you?
I have been playing around with NAS and routers for more than 10 years and if I can configure brands like Cisco, Linksys, D-Link, Apple Extreme, Asus and an old Netgear router previously, I don't believe I have misconfigured the Orbi.
- Mikey94025Jan 02, 2017Hero
Sorry, but web security certificates have nothing to do with your router or wireless. This is why we want more info to investigate and explain what's going on for you.
