diftimi
Nov 22, 2016Follower
Orbi configuration
Hello. I intend to replace my current wifi setup at home from a router + 3 APs (gigabit wired) to an Orbi system, the RBK53. I've seen that the recomended way to pair the satellites with the Orb...
William10a
Jan 18, 2017Master
How does the Orbi setup can you your pc and lan cable connection or does it use a smart phone wifi connection thinking about going a Orbi on or two pack only about 1100 square foot to cover.
- st_shawJan 18, 2017Master
You set it up using your PC and a LAN cable. The interface is similar to other Netgear routers. There is also the Netgear Genie and an Orbi app you can download onto your phone to view and change some settings later, but the apps are limited.
