Pauljm
Jul 01, 2018Follower
Orbi constantly dropping internet and rebooting
My Orbi is dropping the internet connection and is rebooting itself every 20 minutes or so. Been working fine for 7 months and all of a sudden doesn’t anymore. Game factory reset multiple times but st...
Jul 02, 2018Guru - Experienced User
For both posters:
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Disable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
Review this and try it out after a factory reset:
