Severt
Dec 14, 2018Tutor
Orbi continually causes Win 10 PC WiFi media disconnect
I installed an ORBI RBR50 router with two satellites connected with wired backhaul this week. Updated the firmware on the router and both satellites. Since changing over to the ORBI, my wireless co...
Dec 14, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. DS is not needed for wired back haul...
Severt wrote:
I installed an ORBI RBR50 router with two satellites connected with wired backhaul this week. Updated the firmware on the router and both satellites. Since changing over to the ORBI, my wireless connection to my Win10 Acer laptop drops routinely (up to 5 times an hour). Sometimes it will go hours between drops. The observables after the drop include:
- My laptop sees no available WiFi networks. In normal usage, I see ~7 networks.
- Running ipconfig after a network drop shows that the media state is “media disconnected”
- I must reboot or run the Windows network diagnostics tool to recover. I then see the networks again. Running the network diagnostics tool reports it “reset the adapter”.
- There are no events found in event viewer showing up at the time of each drop.
- My wired devices have had no drops.
- My IOS devices have had no drops.
- One other older windows 10 laptop has had the same drop behavior and also requires a wifi adapter reset to recover.
My laptop (Acer Spin 13) is about 8 months old and has never dropped from a WiFi network like this. Clearly the problem is caused by the interaction of the laptop and my new Orbit access point or router.
I would love to keep the Orbi network since its coverage and speed is great, but it will be going back to Costco soon if I cannot resolve this problem. Any help would be appreciated.
I have attached the network diagnostics report courtesy of Microsoft.
Severt
Dec 15, 2018Tutor
I have tried the three suggestions received one at a time. (removing all wired connections to see if there is a bad actor on my wired network, Changing the Daisy Chain setting, and selecting specific wireless channels instead of auto). In each case, the drops persisted.
Next step is to contact Netgear support and see if they have any insight.
- ekhalilDec 15, 2018MasterWhen the laptop is connected to Orbi, can you please check in the web GUI if it’s connected on the 2.4 GHz ir the 5 GHz? Also monitor if it will be hopping and changing between the two bands. Also see if you see events relatability to the laptop’s IP address in the Logs >> ADVANCED >> Administration >> Logs).
Also please reserve an IP address in Orbi for the laptop’s MAC address. (under >> ADVANCED >> Settings >> LAN).- SevertDec 15, 2018Tutor
Based on the last suggestion, I checked the log but found nothing that appeared to be relevant. However it is peculiar in that it only has events starting today. I expected that it would have events from the entire week that I have owned it . What is also strange is that the first event in the log is:
Initialized, firmware version: V2.2.1.210] Saturday, December 15, 2018 08:17:44
I don’t know what “initialized” means. Perhaps the router had an unplanned reboot and at that time cleared its logs?
Next, I did check and have seen that my laptop has switched once in the past hour from the 5ghz to 2.4ghz. I also noted that after a drop and subsequent restart of the laptop wifi adapter, the laptop connected to a different satellite. (The satellites are roughly equidistant.) I also noted in the attached devices tab that two devices, an xbox and an amazon echo, were shown as connected via wire, whereas they are both wireless.
I did reserve an address in the router for my laptop, but this does not fix my problem.
Finally, I can now recreate the problem. When I run a download speed test from speedtest.net, my wifi drops and I need to restart the adapter. Sometimes it takes a couple of tests, but I will get it to fail.
Thanks to all that have suggested things to try.
- FURRYe38Dec 16, 2018Guru - Experienced User
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
