Bluegrass1908
Jan 26, 2018Guide
Orbi disconnects from internet intermittently
I bought an Orbi system with two satellites (RBR40). The Orbi disconnects from the internet every so often and, after a while, reconnects. Here's what I figured out already: 1) It's definitely th...
Mar 12, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
SC3 wrote:
Same issue. Bought about 30 days ago. Now system intermittently disconnects devices from the internet.
0703kb
Mar 13, 2019Star
Get the same problem reported. I’ve found that a quicker reboot is to pull out network cable from router and plug it back in. Saves a re-boot. However, after 12 months of the system working well its hugely frustrating that it drops the WiFi now at least twice a day. Can’t find a fix online. Anyone with any good ideas. Last time I tried Netgear phone number I hung up after being in a queue for an hour.
- AlmondRocaMar 13, 2019TutorSorry to hear that. If you bought it with a credit card it may have an additional year of warranty coverage. Safe to say unit is defective and that other customers are experiencing similar issues.
- FURRYe38Mar 13, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.Has a factory reset and setup from scratch been performed?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Try new FW?
0703kb wrote:
Get the same problem reported. I’ve found that a quicker reboot is to pull out network cable from router and plug it back in. Saves a re-boot. However, after 12 months of the system working well its hugely frustrating that it drops the WiFi now at least twice a day. Can’t find a fix online. Anyone with any good ideas. Last time I tried Netgear phone number I hung up after being in a queue for an hour. - FURRYe38Apr 22, 2019Guru - Experienced User
Any progress on this?
0703kb wrote:
Get the same problem reported. I’ve found that a quicker reboot is to pull out network cable from router and plug it back in. Saves a re-boot. However, after 12 months of the system working well its hugely frustrating that it drops the WiFi now at least twice a day. Can’t find a fix online. Anyone with any good ideas. Last time I tried Netgear phone number I hung up after being in a queue for an hour.- 0703kbApr 25, 2019StarI did the major software update once it was an option via the app, and this seemed to solve the drop out problem, but reduced the WiFi speed to around 40% of what it was (60mb instead of the usual 200mb speed). So last week, the app informed there was an additional software update which I clicked to install. Speed is back to 200mb but have had 3 drop outs in the last 2 days. Is there an easy way to uninstall the last update?
- FURRYe38Apr 25, 2019Guru - Experienced User
Try a factory reset on the system first and setup from scratch.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
