Deez72
Feb 06, 2018Tutor
Orbi Dropped connections
Orbi system is pure garbage and a waste of 400 dollars. Constant lose of internet, terrible WiFi speeds, dropped connections , the list goes on. I have even called support and the only option was to change my WiFi channels. The product is half baked, and customers should get their money back. Don’t buy this product.
- PyroDogApprentice
wrote:Agreed. I keep getting constant drops on anything connected to my satellite. Pinging the router from my desktop that's wired into the satellite has 1% packet loss (attached)!
I had the exact same problem as you do. Reverting back to firmware V2.0.0.74 fixed it in my case.
- tsigLuminary
Ok. Good luck with whatever you change to.
- Retired_Member
mine has been working ok since November. several auto firmware updates ( i don't do beta). simple router to sats setup and dozens of devices.
- martyfpLuminary
mine works brilliantly. hope you find something that works for you.
