RadDoc
Sep 19, 2017Follower
Orbi dropping connections
I am having an awful time with my orbi router and satellites. I have went through tech support back in July with a little bit of improvement but not am back to constant disconnections and dropping of...
DarrenM
Sep 21, 2017Sr. NETGEAR Moderator
Hello RadDoc
What firmware version are you on? Have you tried the latest update?
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
DarrenM
cinek
Sep 21, 2017Apprentice
DarrenM this firmware does not fix s***. I just got another drop a week after the last one. Running 2.0.0.72
- aazSep 21, 2017Virtuoso
cinek wrote:DarrenM this firmware does not fix s***. I just got another drop a week after the last one. Running 2.0.0.72
What kind of drop are you experiencing? Is it local network (can you ping other devices on your network) or just internet connections?
Is your Orbi in router or AP mode?
Have you checked the ISP lease for the IP address? Wondering if the lease is expiring and not renewing. I have been running stable for over 4 weeks now after having to turn off UPnP on the Orbi because of an issue with some of my devices.
