shanwa
Oct 24, 2017Tutor
Orbi dropping internet connection finally resolved!
Hi Everyone, So I've had countless issues with my Orbi RBK50 where I've been frustrated, called support, sent a number of support messages, with no response. Support even initially asked me to ta...
sleepr88
Dec 28, 2017Apprentice
This is NOT the solution for the disconnecting issue. I don't know what they did with the last update, but I would no longer buy this... it's terrible with multiple disconnects dally, making my home control items not work correctly... I need suggestions for what to switch to now please? I have had this system for a little over a year, and it worked great up until a few weeks ago... NETGEAR can NOT seam to figure out how to fix it... it's a lot of $$$ wasted
- sleepr88Dec 28, 2017ApprenticeI would NOT recommend the Orbi. I have had mine for over a year (and it used to be awesome), but a firmware update 6 or more weeks ago has made it junk. It disconnects multiple times, day & night. The disconnects mess with all my home control items(tired of having to reset some of them). And the satellite is in the bedroom, so as it cycles back to reconnect, it becomes a very annoying night light. At first it seemed like a problem with my ISP, but I quickly figured out it was my Orbi system. Netgear doesn't seem to be in a hurry to fix the firmware either. And there is no way to turn off the automatic updates and/or roll it back to one that worked. I am frustrated, especially for what it cost. I am trying to figure out what system I should change to? Suggestions appreciated. Thanks.
- seurat0109Dec 29, 2017Aspirant
sleepr88,
I solved the problem by putting the Orbi in Access Point (A/P) mode.
I got involved in a detailed thread that covers the entire process. See the following link:
https://community.netgear.com/t5/Orbi/Ap-mode-or-router-orbi-rbk50/m-p/1454074#M17404
Since I put the Orbi in AP mode I haven't had a single drop.
Wayne
- guzzijasonDec 29, 2017Apprentice
AP mode on the Netgear is not a panacea, and should not be used if your upstream modem is in bridge mode.
In my own network, I have a dedicated firewall gatway that acts as my primary router behind the cable modem. I have the orbi router connected to this, but I still choose to use router mode on the Orbi for various reasons. I could choose to use AP mode if I wanted to, but I'm not at this point. Point being, I run the Orbi in router mode, and it works just fine for me. The only unexpected drop I ever had was when the power cord was accidentally pulled out of the wall.
