trippw
Jul 04, 2017Star
Orbi dropping internet connection
I purchased a netgear orbi router last month and have had problems with it dropping internet connection almost daily. The orbi representative suggested I get a new system because they had tried all of...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
DarrenM
Jul 14, 2017Sr. NETGEAR Moderator
Hello Crazyb24
What issues are you having on the latest firmware?
DarrenM
Crazyb24
Jul 14, 2017Guide
I continue to experience disconnects, but it seems to be worse. It does not seem to reconnect and forces me to turn off wifi on my phone (Galaxy S8plus).
I did go through the process of doing a factory reset on my RBR50 today and that did not improve the situation.
It also appears to be primarily affecting my Galaxy S8. Other connected devices do not seem to be having this problem (no one else in my home is complaining of disconnects).
I have had the same problem with previous firmware revisions as well, but I disconnected one of my two satellites and that seemed to clear the issue up. That solution has not worked with 1.12.0.18.
- JamessimmeringJul 15, 2017Star
Try turning on Beam forming and Mu Mimo. I had issues after the update with samsung i 5. This seemed to have helped. (fingers crossed) and yes there is no way to cut down the power on the 2.4 ghz side that I can see. The update did away with that option. (I am not an expert just a frustrated user like yourself)
Crazyb24 wrote:I continue to experience disconnects, but it seems to be worse. It does not seem to reconnect and forces me to turn off wifi on my phone (Galaxy S8plus).
