trippw
Jul 04, 2017Star
Orbi dropping internet connection
I purchased a netgear orbi router last month and have had problems with it dropping internet connection almost daily. The orbi representative suggested I get a new system because they had tried all of...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Killou92
Jul 15, 2017Tutor
I have the same issue on my Galaxy S8....
- JMU1998Jul 15, 2017Luminary
IPhone and iPads have improved a lot with new Firmware for me but my Samsung s8 plus and Sony Xperia tablet are still dropping connections randomly and frequent, making it worse since now there is no way to lower 2.4GHz radio or disabling, before when I had 2.4GHz disabled my tablet never had any drops.
- JamessimmeringJul 15, 2017Star
Try turning on Beam forming and Mu Mimo. I had issues after the update with samsung i 5. This seemed to have helped. (fingers crossed) and yes there is no way to cut down the power on the 2.4 ghz side that I can see. The update did away with that option. (I am not an expert just a frustrated user like yourself)
- jj777Jul 16, 2017Guide
I got sooooo tired of all this nonsense. Daily internet disconnects. Hours on the phone. Firmware updates fixing one thing and breaking two others. Inability to keep connection of bedside iphone (since beginning) used for internet radio at night. Thank goodness for Coscto. Now with Eero Pro and NO issues. Now that I finally get to experience fast/reliable internet, even if I couldn't return Orbi, I'd sell it on ebay and buy something else...it would be worth the financial loss...
- lgalliher56Jul 16, 2017Aspirant
That is interesting. I am still having a couple of drops a day. One time today when no one was on the network was happening and hadn't been for quite a while. I had looked at Eero, but Orbi had slightly better reviews and a better price (for 3 units) on Amazon. So I'm thinking I will be returning it. What is your set up like? Did you get one or two satellites? How many devices access your network at a time, typically? One thing I like about Orbi is the dedicated channel between router and satellite, but if the router's not working that doesn't mean a lot, does it?
