trippw
Jul 04, 2017Star
Orbi dropping internet connection
I purchased a netgear orbi router last month and have had problems with it dropping internet connection almost daily. The orbi representative suggested I get a new system because they had tried all of...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please post the issues you are having or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Jamessimmering
Jul 15, 2017Star
Try turning on beam forming and mu mimo. Not sure but for me that seemed to help
