saw676
Dec 07, 2016Tutor
Orbi Dropping VPN Connection
I recently setup the Orbi in my home and I am experiencing frequent VPN drops on my work computer. I am using the Cisco AnyConnect software for the VPN login. I am assuming that the Orbi may be att...
peteytesting
Dec 08, 2016Hero
hi so are you wandering about the house with a wifi client that has vpn connected ? as if so that in its self will cause the vpn connection to drop as the client device moves from sat
to router etc
saw676
Dec 08, 2016Tutor
I am stationary in the same room as the satellite and the connection is dropping. Is it possible that my connection is going back and forth between the satellite and router? The router is in the basement below me, so I would think the connection would stay on the satellite which is 10 feet away.
