saw676
Dec 07, 2016Tutor
Orbi Dropping VPN Connection
I recently setup the Orbi in my home and I am experiencing frequent VPN drops on my work computer. I am using the Cisco AnyConnect software for the VPN login. I am assuming that the Orbi may be att...
mj55
Dec 22, 2016Initiate
Same issue. Orbi firmware is up to date. I'm using Cisco AnyConnect on Windows with ethernet to router which makes me think it's not specifically related to wifi.
- DESIi1Dec 24, 2016Star
My system is dropping the webcams, I can see the WiFi signal dropping to zero on both the Router and the Satellites using the Acrylic WiFi analysis program on my desktop. There seems to be a definite stability problem looking for a Firmware update.
- DarrenMDec 28, 2016Sr. NETGEAR Moderator
Hello Desli1
Have you tried to disable beamforming in the advanced wireless settings?
DarrenM
- saw676Dec 29, 2016Tutor
I confirmed on my work PC that it only supports 2.4 gHz. Because of this, the only thing I can think of that is causing the drop would be if it is switching from the router to the satellite and vice versa. Is there any way to assign a device specific to either the satellite or router? I do not know why it would continue to bounce back and forth if I am not moving around. This happens several times a day. I do notice when I am joining a Skype call or using more bandwidth, it happend more often. Anyone have any other ideas to resolve?
