shreejipix's avatar
shreejipix
ORBI dropping wifi connection
I just setup my new ORBI RBK30 with router and satellite configured correctly. Since then it has never been a smooth ride. The wifi keeps dropping connection every few minutes. As part of setup, I changed my SSID and password.
Strange enough, and I haven't figured out a pattern, but when I lose Wifi connectivity every few minutes, I can reconnect by using old/default router password even when I have changed my wifi password.
All my wired connections are working without any issues.
I also made sure that the Satellite connects to the Router and shows a solid Blue light when connected meaning that it's placed at an optimal distance to the router.
The router updated the firmware on it's own and now it's at version 2.0.0.56
1 Reply
  • there was no change in terms of the issue I was facing. Wifi connection still keeps dropping every few minutes.
