T-R's avatar
T-R
Orbi drops internet
Orbi drops internet (RBR20 Orbi AC2200 Tri-Band WiFi Router)
Router Firmware Version
V2.7.3.22
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
    Does the top ring turn on PINK when this happens?
    Armor, Circle, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
  • FURRYe38's avatar
    • T-R's avatar
      T-R
      Thank you for the quick response.  I have performed the suggestions you recommended, now I will wait to see if there are no internet drops.
      (Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
      Has a factory reset and setup from scratch been performed since last FW update?)
      Regards
      • FURRYe38's avatar
