thebishop
Feb 01, 2017Apprentice
Orbi drops wifi for iPad Pro, iPhone 7 and Macbook Pro intermittently
Running 1.4.0.34 on both main Orbi and sattelite (main and sattelite are on different floors with wall between, perhaps 20-25 feet distance straight line). I generally have "5 bars" of Wifi on al...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
ryman982
May 29, 2017Tutor
I'm having major issues with my AppleTV now... ended up troubleshooting with Apple for a while the other night but the system just can not stay connected to my Orbi. I have an Amazon FireTV in another room and have had absolutely zero issues with it. This also seeemed to suddenly happen within the last week or two.
Seeing that I rely entirely on wifi to power my televsion programming, is there an answer for this in the foreseeable future?? The wife is going to personally strangle someone at Netgear if we can't get Mickey Mouse on the next time the 2 yr old throws a temper tantrum!! :).
wchp
May 29, 2017Luminary
See my post here: https://community.netgear.com/t5/Orbi/Intermittent-internet-connectivity-outage-with-Orbi/m-p/1291468#M7496
keys are:
Implicit BEAMFORMING and MU-MIMO DISABLED
Set 2.4GHz to fixed channel ( 1, 6 or 11)
Reduce broadcast power on 2.4GHz to 75%
see if that resolves your connectivity
- ryman982May 29, 2017Tutor
wchp wrote:See my post here: https://community.netgear.com/t5/Orbi/Intermittent-internet-connectivity-outage-with-Orbi/m-p/1291468#M7496
keys are:
Just made the recommended changes and it apperas to have fixed everything as of right now! Thank you very much.
- lovingbenjiMay 30, 2017Star
I myself still has the satellite constantly disconnecting, and tips to have it work permanently ?
It is not very far from the base (appartment, I would say 6meters away with no "big" walls within, same floor).
- wchpMay 30, 2017Luminary
Not sure what a "big" wall is. The Orbi uses 5GHz backhaul freq. This has far more trouble penetrating concrete, stone or as in my house 1945 lathe with wire mesh and plaster. Another possibility is they are actually too close ( I know, sounds silly )
Personally, I would try moving the satellite to another more distant location from the router (possibly with less physical obstruction. One of my satellites works better at 12m line of sight than 5m through two walls. )
A good write up here: http://www.4gon.co.uk/solutions/technical_factors_affecting_wireless_performance.php
