Itsjustinyo
Apr 09, 2019Aspirant
Orbi Ethernet Backhaul and Guest Network
Hi,
I recently purchased a Netgear Orbi RBK50-100NAR system with one RBR50 (router) and RBS50 (satelite). My goal is to create a wired backhaul to the RBS50 unit and a guest network available a...
Apr 09, 2019Guru - Experienced User
Yes it's supported.
For wired back haul:
Set up IP address reservations for each satellite and devices on the router as you add them to the router. The satellites need to be set up via wireless first. Then connect 1 satellite at a time to the ethernet LAN cable. Wait 5 minutes and the top led on the satellite should turn on BLUE. Set up an IP address reservation for the 1st satellite. Continue to do the same thing for the 2nd satellite. Then follow up with your devices.
You only enable Guest Network on the RBR, the rest is automatic and guest network will appear on both units.
Itsjustinyo
Apr 10, 2019Aspirant
Hi,
Both units are running Firmware V2.3.1.44 and the modem is a Netgear CM500.
I reserved the IP address for the Orbi Satelite and it matches what I am seeing in the Attached Devices list. The Connection Type is still shown as 5G and Backhaul Status is Poor. I rebooted the Satelite and I see the same thing. Am I missing a step or something?
What does the conneted device page look like when this is working with an ehternet backhaul?
Thanks for the help!
Justin
