davispw's avatar
davispw
Initiate
Jul 12, 2017
Orbi factory reset itself after update
MY ORBI FACTORY-RESET ITSELF WHILE AUTO-UPDATING TO 1.12.0.18 LAST NIGHT!
What a pain to wake up to this morning. Anyone else?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello shawnglan
    Have you tried to connect with a wired device and go into the wifi settings and return them to what they use to be?
    DarrenM
  • Me to. I am trying to reset my orbi wifi but my wifi is not recognizing orbi wifi so not able to reset.
    Any solutions?
    Netgear didnt do the right testing. Before releasing.
  • same thing happened last night, the router (RBR50) reset itself after upgrading to 1.12.0.18 firmware.
    all settings are lost...
  • Same thing happened to my Orbi last night.  Yoohoo, Netgear, you should take a look at the update you're pushing.
