mgillen's avatar
mgillen
Tutor
Jan 17, 2018
Orbi firmware 2.1.2.18 issues
We'll see if the stability issues are improved for other devices, but my Galaxy S6 still has errors "an authentication error occurred".
I pluged in a netgear as an AP so that I an use my phone on my network...
  • mgillen so your connected device list is OK? Sattalite showing as separate or as a attached device?
    • mgillen's avatar
      mgillen
      Tutor
      My devices show up properly as they did before. My satellite shows up as a "Connected Satellite".
      *Correction to my first post. Connected an ASUS router as an AP for my Phone to use.
      • JMU1998's avatar
        JMU1998
        Luminary
        mgillen Took v2.1.2.18 a few hrs ago did factory reset, nvram clear now sattalite does not show as connected sattalite but as attached as a device to the main Orbi unit! Yes I rebooted both several times as well anyone else seeing this? a devices show connected to main unit as well so nothing fixed for me.
  • Not to steal this topic, just upgraded to 2.1.2.18 from 2.1.2.12. Can't say anything yet about the system stability but immediately saw that NOTHING has changed in the "attached devices" tab. Both satellites with ethernet backhaul are not shown as satellietes but as other wired devices, anything wirelessly connected to a satellite is shown as wired to the router, etc.
    I wonder if Netgear even has a QA department.
    • sleepr88's avatar
      sleepr88
      Apprentice
      Netgear, since you can't seem to fix the Orbi, are you going to start issuing refunds? or exchanging everyone to Orbi Pros (which doesn't appear to have these problems, because you value business customers over regular consumers?)?
      • mgillen's avatar
        mgillen
        Tutor
        I reinstalled the Orbi on Wednesday, 1/24/18.  It rebooed on Friday, 1/26, but has been stable since.
        Of course, I still have the Galaxy S6 Authentication error issue, but am living with it.  I may split the SSID latet this week since it should work-around that issue.
