bhenry
Jun 16, 2020Tutor
Orbi Firmware page shows 2.5.1.16 for router BUT says waiting for connection for Satellites
The downloads page for both my Router and Satellites show the 2.5.1.16 firmware is available. On the web UI though the orbi just shows a firmware update for the router to 2.5.1.16. IT shows nothing...
Jun 16, 2020Guru - Experienced User
You can manually update the RBS by logging into there web pages and sending the FW file to the RBS:
bhenry
Jun 16, 2020Tutor
So I got one to manually update. The other keeps giving an error with the password, same admin password as worked on the router and worked on the other satellite.
I verified the satellite that I manually update is at the 2.5.1.16 firmware but the firmware page in the Orbi page still shows the satellite at 2.5.1.8.
The way the orbi handles these things seems very disorganized and unstructured. How do they not accurarelty report the firmware.
- FURRYe38Jun 16, 2020Guru - Experienced User
Be sure to use the RBS web page and load the v16 FW file directly using the RBS web page. Connect a wired PC to the back of the RBS.
