MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Nov 06, 2019Guru - Experienced User
Thats good for you, glad your appart of the group that didn't need a reset. Some don't and yet there working on v.38. Others seem to need a reset and then things work:
At each FW release there seems to be this mixed bag of users with issues and some that don't see issues after a update and some that do and need a reset. I do agree, NG needs to make the FW update more stablized and less automatic and more automated.
I prefer the manual FW load and reset and setup from scratch. No problems with this method. This is my perference.
Enjoy.
MikeG63 wrote:Couldn't agree more, in my case no reset was needed, just a router reboot after the upgrade. All that is really required is good quality control and a good quality assurance play book / automated procedure. Also STOP tinkering under the hood!
Retired_Member
Nov 06, 2019
FURRYe38 wrote:
I reprefer the manual FW load and reset and setup from scratch. No problems with this method.
But.....you've never explained why you would execute a manual update in the first place, especially if your network is working fine.
