MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
Dec 11, 2019Guru - Experienced User
Were you able to give custom names to devices past 3 or 4 name changes?
dnonnema wrote:
The upgrade to .38 on my RBK50 was easy and naming is operational post upgrade. I seem to be in the minority judging by all the responses in this thread.
NG has some ‘splaining to do.
Tinkman65
Dec 11, 2019Aspirant
No, I think it only allowed me to change 2 device names after updating to .40 and after that I could not udate any other devices.
- MikeG63Dec 14, 2019Apprentice
Just as an FYI..........I have upgraded to v2.5.1.8 this morning without any dramas, and this firmware release appears to have resolved the device naming / icon issue introduced in v2.5.0.38.
Have fun......
- Sylvain24Dec 16, 2019Tutor
Thanks, and for 2.4/5Ghz split SSID, is it working with v2.5.1.8 ?
- MikeG63Dec 16, 2019Apprentice
Sylvain24 wrote:Thanks, and for 2.4/5Ghz split SSID, is it working with v2.5.1.8 ?
Sorry I can't say. My 2.4 Ghz and 5 Ghz devices are automatically assigned the correct frequency according to what they support using the one SSID. I haven't found a need to have two separate SSIDs. Also I don't believe the https certificate issue has been fixed though in v2.5.0.40 - unless I have missed something and need to manuallly renew the certificate after applying the update, but I haven't seen any instructions on that!.
- FURRYe38Dec 16, 2019Guru - Experienced User
