MikeG63
Oct 22, 2019Apprentice
Orbi Firmware Update 2.5.0.38
Does anyone have any details on this new firmware upgrade?
- Oct 22, 2019
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.
[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Enhances the device recognition mechanism of the attached devices list.
[Bug Fixes] Fixes the compatibility issue with Sonos devices.
MikeG63
Dec 14, 2019Apprentice
Just as an FYI..........I have upgraded to v2.5.1.8 this morning without any dramas, and this firmware release appears to have resolved the device naming / icon issue introduced in v2.5.0.38.
Have fun......
Sylvain24
Dec 16, 2019Tutor
Thanks, and for 2.4/5Ghz split SSID, is it working with v2.5.1.8 ?
- MikeG63Dec 16, 2019Apprentice
Sylvain24 wrote:Thanks, and for 2.4/5Ghz split SSID, is it working with v2.5.1.8 ?
Sorry I can't say. My 2.4 Ghz and 5 Ghz devices are automatically assigned the correct frequency according to what they support using the one SSID. I haven't found a need to have two separate SSIDs. Also I don't believe the https certificate issue has been fixed though in v2.5.0.40 - unless I have missed something and need to manuallly renew the certificate after applying the update, but I haven't seen any instructions on that!.
- FURRYe38Dec 16, 2019Guru - Experienced User
