BretD
Jun 04, 2018Administrator
Orbi firmware update v2.1.4.16 availability
We’ve been monitoring issues that some customers have experienced in OrbiOS 2.1.4. In response, we’re releasing firmware that provides a permanent fix for the homekit issue along with various other f...
Jun 05, 2018Guru - Experienced User
Is there any network switches in between the router and satellite? If so, Mfr and model# please.
Is daisy chain disabled on the router before connecting the ethernet cable?
manofice wrote:
Still haven't fixed ethernet backhaul. I updated my RBR50 and satellite to this firmware, all was well for a minute or two, then the network crashed and had no internet. Multiple reboots and still no internet. I unplugged the ethernet backhaul link and rebooted the router and all is working again on the wireless backhaul...ugh.
manofice
Jun 05, 2018Virtuoso
No, no switches in between. Was working OK prior to the firmware upgrade. After the firmware upgrade, systems were all running ok for a few minutes, then it all came down.
- FURRYe38Jun 05, 2018Guru - Experienced User
Ok, if you have done reboots, disabled Daisy Chain and such, I would do a factory reset on both satellite and router and set up from scratch.
After the router is set up and Daisy chain is disabled first. Disconnect ALL other LAN cable devices accept for 1 wired PC. Re-add the satellite via wifi. Let is sync and get BLUE led on top. Then reconnect the Satellite with the ethernet cable. Give 5 minutes and wait for the top BLUE led to appear. YOu could do this with the Satellite near the router if you want to, then if you can get the satellite synced with wired back haul, turn off then replace back at remote location. Then re-connect all other LAN devices back to the router.
- computersteveJun 05, 2018Apprentice
I see that performing a factory reset is being mentioned again.......... I do hope we don't have to do this with every firmware..... I mean I have an orbi outdoor unit & having to unscrew it is a pain in the a$$ =(
